trying to make a clock with mostly black background, but am unable to figure out how to get the numbers to show up natural (not black) to show up against black background, been trying to figure it out in masking. not having much luck. any ideas??
Can you take a screenshot of LightBurn showing your design?
It looks like your background image is a bitmap.
In that case you have a few options:
- Edit the bitmap to incorporate your numbers
- Convert the background to a vector so that you can modify shapes to accommodate the numbers
- Potentially mask out the black portions of the background
This would be simplest if the entirety of the design was in vector format but I suspect that may be difficult. In that case it may be easiest to modify the graphic to include the numbers in the design.
will try thanks
