Clearing previous print files to Xtool D1Pro
Hi all, new here and trying to learn Lightburn. When I get the settings wrong on a project and the alarm goes off…regularly. When I turn the Xtool D1Pro 20 w off and on again later, it decides to print a previous job again. How can I see when jobs are spooled like as in a printer setting for a normal printer?
Not sure why it keeps printing a previous test job over and over again.
Many Thanks
That sounds like something going on with the controller, not LightBurn. Try reading the SD card from the laser in your computer to see what’s on there. I’m guessing there’s an extraneous file that’s queued to be burned and it’s somehow repeatedly burning the same file.
Thank you, I looked up the sd card and the files are frame.gcode and temp.gcode.
Should I delete these? I didn’t save anything to it as far as I know.
I’d suggest taking a backup of them and then deleting them to see if the behavior changes. I believe your machine may use the SD card on its own to manage streamed files.
