Clipping or slicing a shape
If you have a shape, or anything really, is there a way to clip or slice off a corner or small part of the shape by drawing a line and then removing the unwanted portion? Kind of like an eraser tool would do.
Create a shape that you will use as a cutter. Position the shape appropriately. Then first select what you want to cut, then the last selection should be the cutter.
Then Tools->Cut Shapes.
Awe damn! The solution was right in front of me! Thanks for bringing it to light. Problem solved!
