Attached is a file with a circular array of numbers. I have manually done the 0,1,2.
I want to know if there is a way to generate LazySusan2.lbrn (67.3 KB) the numbers all the way around, from 0…60
I’m close…
So I made some text, typed in dd, and then went up and changed the text type to “Serial Number”. Then I created a circular array with these settings:
The work area looks like:
And the preview looks like:
I’m on the clock though, and probably should go do actual work I have in front of me. Hopefully that helps you though.
Some pertinent documentation:
Variable text feature: https://github.com/LightBurnSoftware/Documentation/blob/master/VariableText.md#variable-text-in-lightburn
The format strings: https://github.com/LightBurnSoftware/Documentation/blob/master/VariableTextFormats.md
dd THEN preview is the trick.
Thanks!
