Anyone know, will Cnc Xpro5- controller work in Lightburn?
Some told me, that this controller will understan G-code, and
Grbl firmware.
So, if so what could be a problem…?
Does it have the place to laser module?
Perhaps you have to configure something…:
Pay attention to specs:
And it seems to work with GRBL give it a try:
I’m not seeing one of these controllers in the company equipment database.
We have been occasionally asked about this controller. The CP210x serial chips are seen in better controllers. This is a good sign. LightBurn communicates with several controllers that use this chip using the standard driver. Communication is expected to work on your Windows 10 device with the standard driver.
The maker of this controller suggests not using FluidNC with it. I will look at the FluidNC documentation to see if there’s a reason why people are attempting to use it instead of the manufacturer’s firmware. Several of our staff are using FluidNC and I’m swapping a Mach4 based controller out of my QueenBee to do it.
I can’t say for certain yes or no but it appears promising. (Still reading)
