Hello,
CNTRL C / Z / V seems are not working under LigthBurn 1.7.00 or did I missed to configure something after installing this brand new version?
Thanks a lot
Hello,
Thanks a lot
Hi Hector - could you tell us what operating system you are using?
Windows/MacOS/Linux?
As well as what language you have LightBurn set to?
This is language specific - What language do you have LightBurn set to? We’re aware that our translators broke some of the keyboard shortcuts in a couple of languages and we’ll have an update out shortly to fix that.
Hi using Windows 11 PRO in Spanish in version 1.06.3 shortcuts works excellently, thank you to keep me posted
Hi solved switched to English and it did work!
Hi solved switched to English and it did work! wait for new version meanwhile I can use it in English best regards
They are just reset after every launch. If you enter in prefs / hotkeys you can press in “reset all” and it will work, but will be clean once you launch again LB.
Thank You, your help is very much appreciated
