I just received my monport k40. It looks like the carrier was pretty rough with the handling. The chasis was dented and the X gantry was warped to the point the belt was rubbing against slider of the linear rod. I was able to un-warp it and fix it.
After setting up the water cooling and trying to fire the first pulse, the laser did not produce a pink beam inside in the tube, also failing to burn or even darken the tape I put on the first mirror.
The LCD shows:
Water Protection: ON, which is ready
Laser signal: ON, when pulse is pressed
Ammeter: 0 mA, always, no matter if knob set to min or max
Looking into the control chamber, I noticed pulse tests make the fly transformer arc like crazy. It was arcing 3 ways, between PSU chasis, fly transformer, and the 3 wires between the PSU board and the fly.
I tested a fix by unscrewing the fly and letting every sit further apart. No more arcing to the chasis, or the 3 wires. However I still see arcing inside the gaps in the fly’s core.
All the while, not a single sign of life from the tube.
My question is this:
- Is this a dead PSU? or the PSU is fine, but a faulty tube that is causing the PSU to arc? What do I test next to find out?
