Co2 laser chiller
I was working regularly on my CO2 laser. It is summertime, so I bought a fan to blow on my chiller, so that the chiller was not overloaded. Suddenly my machine reached the temperature of a 30 degrees celsius. High temperatures of the water in the chiller was not the unusual thing, every day it would get to like 28 or 30 degrees, but the chiller would lower the temperature effortlessly. But today it stayed at 30 degrees for a whole hour. I switched off the machine and started dismantling the chiller. I cleared all the tubes, all areas where the dust was and also I changed the water. It did not help. The water pump is working and also the fans in the chiller seem to be working…
Any help? What is the best solution?
Most likely, the chiller’s refrigerant has leaked away, so it’s no longer cooling the water.
In the unlikely event it’s still within the warranty period, you may be able to file a claim. In my experience, you must pay shipping back to the seller for an “inspection”, whereupon they will be free to deny your claim without recourse.
With the possible exception of truly industrial chillers, there is no provision for recharging the refrigerant. While you might find an air-conditioner repair shop that can install fittings on the chiller’s refrigerant loop and recharge it, I suspect the cost would exceed buying a new chiller.
I’m not sure I follow you here.
I don’t know any glass tube manufacturer that recommends temperatures that high or close to the 90F number.
I also don’t know where you are. I lived quite a while in the Phoenix Arizona area and over 115F is not that unusual. I have a 5202 chiller and I run mine at 20C up till it gets to be 110F outside, where I call it quits.
If you can get it swapped out, as @ednisley suggests, that would be best. I looked around Phoenix area for someone to fix one of mine and couldn’t find one. They all work out of their trucks and charge $150 for a service call on one of these, that doesn’t cover the actual repair. So you’re close to a new machine cost.
If you can find someone to add the necessary plumbing, then you can find out if the compressor went out or it’s low on coolant. If the compressor is broken, it’s not worth a lot.
Let us know how you figure it out.
:grinning_cat:
Could it be that it is a CW 3000 and not a 5000 series?, the difference is that the first is a passive cooler and cannot cool significantly below its ambient temperature.
30 degrees Celsius - is not something a CO2 tube will break at. It is not optimal temperature but half of Asia runs at a somewhat higher temperature as standard without problems.
optimum water temp should be around 18C (65F). you lose about 1% output power per degree above that, and the tube will generally degrade more quickly at higher temps.
At the same time, you should never cool below or even near the ambient dew point as condensation can form on it and destroy the optics or short out the hv power on the outside of the tube.
that can be deceptive in that it may be a “dry heat”, but like 95F 45
I have never had mine produce any kind of condensate. I’ve run with thunderstorms in the monsoon season and dew point of a dew point using 95°F with 45% humidity is approximately 73°F. I know I’ve run in 60% relative humidity or more still at 20C.
I run 20C or about 68 deg and, for here, high humidity. Tube stays cool but nothing has ever condensed on it. I doubt the outer part ever gets as cool as where the internal coolant flows. It hasn’t in mine …
Maybe down in the south you have this issue, but not in the sw usa.
:grinning_cat:
If you’re talking about a fan only style chiller, those units shouldn’t be used on CO2 machines. A compressor style chiller is the way to go.
If you need to get by using a fan chiller then pick up a small radiator or a wind of copper tubing in ice water. You can also use a water pump. You can’t control how low the temperature goes but it’s far better than too high a temperature. You will go thru a lot of ice using this method.
Consistent temperature is the key - when doing large engraving projects, even ± two degrees of water temperature swing can show up in the etch as banding.
A laser tube outputs more power when it is colder, so you would output more power, then less, on repeat, if your chiller can only maintain ± 2deg.
yeah i was typing 95F 40% might seem dry, but that is already dewpoint of 70F.
to be honest i haven’t heard of problems attributed to going below the dewpoint, but then again we don’t really do failure analysis so it could be causing problems no one notices.
running the tube is going to warm it up. while running at significant power, the output mirror-window will warm up from the beam going through it and being close to the arc through the bore. the gas will be a bit warmer than the glass water cooling coil and the outside of the tube will reflect that.
but letting the chiller cool it down while not running would create more opportunity for condensation. then again, it’s not unusual to leave the chiller on while not actually running the laser. so i do wonder why i don’t see accounts which could be condensation problems
yep power is nothing without consistency.
it will definitely spoil raster quality.
also, you will most likely test your settings while cold, get it going as fast as it can and still cut through with a little margin, but since failing to cut all the way through is very problematic, you generally always need to slow it with enough margin for the worst case so it’s a performance penalty that you have to bake into your settings all the time.
The problem is that it is neither 5000 nor 3000. It is the original manufacturer’s chiller, it is really small, only 2L of capacity. It is a compressor style chiller. And really the chiller was doing the great job, it was cooling all over the year without any problem, even the summertime when outside fan helped him. It would go to 30 degrees and not more, but not that often, like every 2 days. I think that the best solution is to buy a new chiller.
At the end I ordered the CW 5200 Industrial chiller, I think it would work without any problem.
The CW that are actually chillers (the CW5200 is) are pretty good.
They don’t seem to rely much on tank capacity for temp stability. I was kind of curious how they keep it as stable as it is under varying thermal loads because compressors only have one speed, build up a volume of liquid refrigerant on the high side, then has issues restarting again until the pressure bleeds back down.
Key difference is the chiller has a hot gas bypass valve that opens when it passes the cooling target, adding heat back into the refrigerant loop.
I’m sure there’s a failure mode where the bypass valve could get stuck open or closed, but I’ve had the chiller stop working several times and it’s always just been low refrigerant. It didn’t actually come with ports to fill or even check it, but we added them.
How to fill it is a little different. On a car AC, you need to use a chart for ambient air temp to find what the right high and low side pressure is. Chiller is supposed to be by weight, and it can chill the water to target and stop the compressor during the fill attempt. I think we’ve been successful at just winging it, but if you overshoot and add too much you can lose cooling capacity (cuts into the room for the liquid to expand) or let liquid into the compressor inlet which can kill it
You called me, but I was out servicing industrial chillers.
But it didn’t make much difference because the important thing has already been mentioned in previous comments.
Normally, when there is a rapid leak of refrigerant (gas), it leaves a greasy residue. If you find something like that in the refrigerant piping, it’s very likely that you’ve found the leak.
If there is no such residue, it would be advisable to check if, when the water is above the desired temperature, the pump, compressor, and fan turn on and keep working. Any of these components is essential and must work while the water is above the desired temperature. Only below the desired temperature should the pump continue to run.
Since I don’t have any information about which chiller it is, I don’t want to “dump” more information that could be more harmful than beneficial.
The problem is how to solve it. As mentioned, returning it to the seller for repair can be very expensive.
I would opt to hand it over to an air conditioning technician, for example, since it’s the same field, and as long as he’s honest, I don’t see why he couldn’t solve the problem. (Lack of parts or parts exclusive to the manufacturer can be a problem.)
NOTE: This is for chillers. There are water coolers that are nothing more than radiators in a car, for example. A fan and a closed circuit where water passes on one side and air on the other. The water never cools much more than the air temperature. Technically, it never cools more than the humid/wet temperature.
Your symptoms indicate that your CW-5200 is set to the wrong mode. If your chiller allows temperature to go to 30-deg but keeps it there. You need to alter some settings for your chiller to work correctly.
CW-5200 chillers have two modes: intelligent mode and constant temp mode. They ship with the settings set to intelligent mode. You want constant temp mode. You must access the chiller’s controller menu and change the mode to constant temp mode along with some other settings that might need to be adjusted.
Different controllers have slightly different “F” parameters. For the T530d controller, the control mode is F3 and should be set to 0. This changes the controller to constant temp mode from intelligent mode.
If you do not have a manual, I suggest trying to find the manual for your controller online or use Google’s AI (Gemini) response to find the method to access the chiller controller’s menu, enter the password, and make parameter settings.
I found a very good AI prompt to get things started was simply “Why is my CW-5200 trying to keep the temp at 30 deg?”. I hope this helps.
5200cw chiller came, I assamble it and everything works perfectly fine.
Glad you’re up again. Here’s the maintenance manual for the 5200 series and the users guide. If you wish to read through them.
Even the fan radiator types (3000 series) have the ability to cool 200F down to something usable, or chill the coolant, in most weather. They are chillers. Since lasers don’t get that hot, it’s an unlikely substitute for the kind of chiller a laser needs.
Have fun.
:grinning_cat:
