Color Palette - Default with new projects
Regarding LAYER
When I have entered values for each individual layer, Save my project, and want to start a completely new project, Lightburn still remembers the values I used from the previous project in the Color Palette
It is possible to :
Question 1:
For each project I save, layers and settings in the Cut/Layers panel together with the graphics, is in the Saved file, and then I start a completely new project, the color palette is set to Default values?
Question 2:
Can I export settings in the Color Palette, to later apply them to another project?
For Question 1, in Edit/Settings, you can set LightBurn to load the default layer settings when you start a new project:
You can set all of your layers back to defaults in the Cut Settings Editor:
As for Question 2, that’s a good use for the Material Library:
Down work - Still not default settings
What did you set as the C07 layer default settings?
