Need some guidance on setting color palette defaults
Welcome. I might suggest starting with the following section of our documentation. The entire documentation is worth a quick review.
If willing, share a bit more detail. It will help focus our responses, as I could interrupt your question several ways.
Thank you. Looks like a good place to start. I have so much to learn.
Depending on how many different materials and effects you need, the Material Library
may be more useful:
Basically, when you have a cut / engraving / etching / whatever that you will use again, you can save those settings with a name for that particular material, where it’s easy to find and apply the next time around.
It also eliminates having to see the difference between two very very similar colors, which is why I use only about three colors for everything. Black, red, blue, maybe green on special occasions: those I can tell apart.
