Color Pallett Labels
I am trying to name the various color Pallett settings so I can bring in an image and assign the named color to it. When I assign it, the text label that I had given it goes away. Is there a way to have the pallett label names stay, so they can be assigned in a project?
Layer names are saved on a per project basis.
Retaining layer names for all new projects I thought that was actually default behavior but if that’s not the case, I believe if you set “Make default” in the Cut layer setting that may retain the layer name for future projects.
In reality, it would likely be better to familiarize yourself with the Material Library, which was created to store settings in and be able to quickly assign them to layers in your project.
