I have four layers want to cut individually. But I also want to cut a light score first of all the layers at one time. If I copy a cut layer path onto the score layer, the cut layer goes away. What is the best way to do this? I would like the four individual cut layers and one layer that combines all of the cut layers
Duplicate the cut layer then change the duplicate to the score layer.
thank for the reply. where is the duplicate layer button?
Select whatever you want to duplicate, right click, duplicate is in the drop down menu or the shortcut key (Ctrl + D).
To select an entire layer hold the shift key and click on the layer in the Cuts/Layers panel.
