Coming from LaserCad, AWC708, I don’t understand how origin is handled.
In LaserCad I just plonk down the material, move the head to where I set origin in LaserCad (usually the middle) , press the origin button on the control pattern, and away we go.
Seems Lightburn treats origin in a different way. Is there a tutorial I can watch to explain it?
If you are using LightBurn with an AWC controller, the origin settings work the same way you are used to. The drop-down where you would choose what origin type to use is not available in LightBurn when using an AWC - As Isaac says, the origin mode is selected on the controller itself.
