ComMarker B4 60w Lense / cor file questions
Hi,
I’ve the 110x110 lense installed with the mfg cor file. I found that the scale was off by ~14% x and ~15 in Y. I’ve made the a correction in the “Device settings” section and it’s much closer BUT I noticed that the corner in one side is slightly bulged. It’s not by a lot but Im in engineering and QC so I have all the associated “personality traits”, having significant trust issues would be an understatement.
  1. if the scale was that far off from the mfg and that corner is a tad bit off is there anything else associated I should be looking out for?
  2. I also purchased the 70x70 and 300x300 lenses post machine purchase so I need to create my own core file. I’ve reviewed the LB YouTube video associated with this procedure. Any words of advice?
3)Back to that “bulged corner” find. Using the supplied CorFile2.exe is it possible to edit the 110x110 core file to fix the bulge or does it require going through the whole cor file creation process?
TIA
