I’m sure this is a noob question, but I’m a fiber laser noob. I have a Commarker B4 20 watt fiber laser. In Lightburn in preview the image looks correct. When I engrave it, the image is backwards and inverted. I would appreciate any help.
I suspect your origin is wrong, but coordinate systems are not my strength.
Usually these can be swapped to correct it. It’s in the Device Settings. Define the other axes as the X axes…
This is how it’s changed with my galvo.
Good luck
It worked perfectly. Thank you.
Jack Wilborn solved the problem. He recommended swapping the X axis to the other mirror. Thanks for your help.
