Como corregir error 20 en linea 2 para que corte mi maquina
Did you accidentally turn on Enable Gcode Clustering in the Device Settings window?
Also make sure your controller type id GRBL only in the Laser, Devices window
no esta habilitado el gcode del clostering y el id del controlador es corecto pero siempre tengo el error 20 en linea 2
With the Lightburn file loaded, click on the Save Gcode button and save to a text file. From that saved file, copy the first 20 lines and paste it in your reply here.
