Ajuda por favor como ligar e desligar o fan do laser
Help please how to turn the laser fan on and off
The fan is most often wired across the power supply to the laser module.
There is no cooling fan control or cooling fan behavior that is adjustable on a majority of diode laser engravers. When the laser is powered and controllable, the laser cooling fan is on.
This is the lowest cost, most reliable way to ensure the laser remains cool when working. If the laser stops from a power supply failure - the fan stops.
Is the noise bothersome?
Muito obrigado pela atenção, sim o barulho é incomodo,
Sou marceneiro e fábriquei um gabinete com porta de vidro escuro a prova de luz forte do laser
Thank you very much for your attention, yes the noise is annoying,
I am a carpenter and I made a cabinet with a dark glass door that is resistant to strong laser light.
