Config for Shapeoko 5
Hi group,
I try to use my Shapeoko 5 2x2 with Millmage. I think I configure it correctly. I also position my X Y Z 0 correctly. I home the machine. When I start the job, I think tha machine start in the wrong direction because Motor start to rumble. I need to emergency stop.
I also have a problem to configure correctly the Bit zero, the tool that mesure the tool.
Any idea? Can you share your config file from MillMage?
Hi Martin.
Check ic this thread for a 3 XXL
If it is a similar configuration.
