I have a Cloudray laser UV P 5W, and i don’t find the drivers compatible with Lightburn.
The machine is connect with a USB A - Ethernet adapter
I can’t use it ![]()
Did you install the CH340 USB driver? You need it for the USB cable to work.
Ethernet is a different game.
Hi
I try with the CH340 USB Driver but it’s the same…
In the device manager, i saw the USB A - Ethernet adapter correctly installed.
Installing Lightburn application i choise EZCAD2 Driver option, as it was recommanded, but the laser ins’t view
You cannot use the EZCAD2 driver with Lightburn.
