Connect Creality rotary chuck to sculpfun icube
Hi,
is there anyone that has connected a Creality rotary chuck to an iCube? Or could assist me how ich could connect them? I can solder,but do not know what the connectors are called or where I can get them.
Maybe someone could help?
Cheers
Joerg
This page states that the connector for the mainboard must be a four-pin JST-XH 2.54 connector:
What this means is that the cable going to the Yaxis motor is way too short to reach a rotary, so you will have to fabricate one that goes from the rotary motor to the controller board.
It can be done. You are not the first to ask about using a rotary with the iCube. I have the 10w iCube, so it is only fair that I ask this question… Where are you going to put the rotary?
Got this from the Sculpfun site:
Can the rotary roller be used with the iCube?
No, it can not. But in May 2025, will have a new rotary roller, designed for iCube series machines.
This sounds like a low profile roller, but no chuck.
Here is the Diode Wiki site by @misken , which you should bookmark and donate to…
Sculpfun iCube series - Diode Laser Wiki.
