Connect lines to shape
Hello!
How to close this lines to shape. I tried many thinks…
TEST_SHAPE.lbrn2 (4,8 KB)
TEST_SHAPE_repaired.lbrn2 (4.7 KB)
The shape seemed to be corrupted, but was repairable using ‘Alt+B’ to break apart the shape, followed by ‘Alt+J’ to auto-join the segments back together as attached.
Ha ha thanks @NicholasL I tried everything but “break apart” you’re a lifesaver.
Break apart can also be found under the Arrange menu if you don’t like key shortcuts, make sure to select the whole shape.
Hello! thank you, perfect solution :grinning_face:
Thanks :+1:
