So it appears that with LB it is easier to create a half and then duplicate and mirror.
You could but as far as i can tell it’s duplicated - not a true mirror, meaning if you want to edit first half the “mirrored” half will not keep up with the changes.
If you create a proper circle and convert it to a path, you’ll see the nodes at the 4 points, like this:
Hover over two opposing nodes and hit ‘B’ over each one to break the curve at that node, and you can just pull them apart:
