I have 2 lines in a drawing and can not connect them to make 1 continuous shape. Can someone help I am stuck.
Thank you in advance,
Kevin
Kevin
you can use the node editor tool in the tool bar on the left. or highlight the lines you want to connect as long as the points are close and go to “edit/close selected paths with tolerance” or “edit/auto join selected shapes”
let me know if that helps
I have tried 2 of the 3 things you recommended. The “edit/auto join selected shapes” will not allow me to use it.
Kevin
can you post a screenshot of the lines you are trying to join?
Any chance you could upload the LB file?
[quote=“Ksheren, post:1, topic:98731, full:true”]
Kevin
Yes upload the file if you are willing. It’s easier to help.
How do I upload it not see a spot to attach a file
In the reply window drag the .lbrn file. Wait for it to completely upload then click reply. Or you can click the up arrow and select the file.
fin.lbrn2 (12.9 KB)
When it cuts it does it 2 steps not continuous
Give me a few
Zoom in close,
fin fixed.lbrn2 (12.5 KB)
Thank you sir. I never zoomed in that close.
Thanks again,
Kevin
hit this button “node editor” if you hover your mouse over it it will give you some hoykeys for it. can you select this and highlight the shape we are working on, then post another screenshot?
(edit) i see that the problem has been solved.
@micrololin diddnt see your reply before i replied. was gonna ask for the file next. good work sir
