Connecting my Omtech AF2028-80 to Lightburn Pro
I followed these steps to connect to my used Omtech AF2028-80 CO2 Laser:
Installed the RDWorks software on my Windows 11 laptop
Click the button to install the required USB Driver
I connected the laptop to the Omtech laser and turned on the laser.
Open Lightburn and navigated to the Laser Window
Click the Devices button and clicked Find My Laser
There was a quick blink (looked like a window opening and closing)
Then nothing happens!
Is there a way to determine what the quick blink was? And what other steps can I take to connect Lightburn Pro to the Omtech laser?
If you have the option I would always recommend a LAN connection, it is the best solution.
In addition to that you should be able to set up your laser manually (also with USB connection). The steps are few and easy to follow, you will be guided through the process.
