I am trying to connect a Neje BL N3000, USB connection, but no luck. Any help would be appreciated!
I look this up and I can only find the module, not a machine… Can you give us a link so we can see what you have?
Do you have reason to believe this laser is supported by LightBurn or are you just trying to see if it works?
What software are you using now to control it? Is there a welcome message you can take a screenshot of when you connect?
Do you have a reference where LightBurn is listed for this particular laser? If so, please link here.
Is that screenshot the only meaningful welcome info or information about the controller that’s available? It doesn’t look promising from this perspective.
Kind of looks like this animal…?
@Shilone it would simplify matters if you could just post a link to the device that has some information on it…
If it’s your machine, I assume you got it legitimately somewhere… where?
Not anymore. I did when I bought the unit 3 yrs ago, but didnt want to spend the money at the time. Now I bought Lightburn and cant use it. That is the only screenshot, sorry.
I’m afraid you will have to dig up some information on it for us to be more help… @berainlb was trying to say is that we need to know if it’s a grbl or some other kind of controller…
I assume this is running windows? The os is important if we need to troubleshoot the issue from the pc side, such as connecting.
With windows, you can see if the device is visible to the os by examining the device manager usb listing. I assume it’s usb?
ok, leaving for the weekend, so don’t look for anything I can find till Monday. Thanks for trying to help!
Ican
find till monday
running windows 10 on usb com 4. working on controller id.
Does the device manager give you any clues? I can get the vendor:product id from the usb connection in the os…
Try this link and see if you get results… the link shows it as vendor&product-id format…
2 lines from report
Description : USB-SERIAL CH340
Device Type : Vendor Specific
Device Name : Port_#0004.Hub_#0003
Connected : No
Safe To Unplug : Yes
Disabled : No
USB Hub : No
Drive Letter : COM3
Serial Number :
Registry Time 1 : 8/3/2023 2:57:31 PM
Registry Time 2 : 7/26/2023 9:10:57 AM
VendorID : 1a86
ProductID : 7523
Firmware Revision : 2.64
WCID :
USB Class : ff
USB SubClass : 01
USB Protocol : 02
Hub / Port :
Computer Name : TERRY
Vendor Name :
Product Name :
ParentId Prefix :
Service Name : CH341SER_A64
Service Description: CH341SER_A64
Driver Filename : CH341S64.SYS
Device Class :
Device Mfg : wch.cn
Friendly Name : USB-SERIAL CH340 (COM3)
Power : 98 mA
USB Version : 1.10
Driver Description: USB-SERIAL CH340
Driver Version : 3.5.2019.1
Driver InfSection : CH341SER_Inst.NTamd64
Driver InfPath : oem177.inf
Instance ID : USB\VID_1A86&PID_7523\7&348b7431&0&4
Capabilities : Removable, SilentInstall, SurpriseRemovalOK
Install Time :
First Install Time:
Connect Time :
Disconnect Time :
Device Name : USB Serial
Connected : Yes
Disabled : No
USB Hub : No
Drive Letter : COM4
Serial Number :
Registry Time 1 : 8/5/2023 5:57:31 PM
Registry Time 2 : 8/3/2023 3:00:10 PM
VendorID : 1a86
ProductID : 7523
WCID :
USB Class : ff
USB SubClass : 01
USB Protocol : 02
Hub / Port :
Vendor Name :
Product Name :
ParentId Prefix :
Device Class :
Device Mfg : wch.cn
Friendly Name : USB-SERIAL CH340 (COM4)
Power : 98 mA
USB Version : 1.10
Instance ID : USB\VID_1A86&PID_7523\6&295c3a96&0&2
Install Time :
First Install Time:
Connect Time :
Disconnect Time :
At a minimum you should be able to connect to the Serial Console from LightBurn. If you connect from LightBurn, can you copy and paste the full contents of the Console window here? Or if you’re familiar with terminal programs, any of those would work as well.
