I am trying to get Lightburn to see my F1 Ultra. I downloaded and imported the F1 Ultra lbdev file from xTool and tried to connect. I am using a fairly new MacBook Pro. Here are the things I have done:
I installed the drivers as outlined on the xTool site for the F1 Ultra.
I ran 'ls /dev/usb and got nothing. So I connected to my D1 and got did get a USB port in the listing.
I changed the settings in the lbdev file from IP/TCP to USB.
It will connect and run just fine using XCS and connecting via USB which is freaky given the results in #2.
I am using the same USB adapter on both machines the F1 Ultra connect with the newer USB-c connection and the D1 connects with the older USB connection.
I also have seen an argument whether you need the Galvo version or not, some say yes, others say it runs just fine of the GRBL version. Either way I don’t know where to go with this. Thank you for any help.
You mentioned USB-C. I read in a different posting that the MAC will not downshift to USB 2 and expects a USB 3 protocol at the other end of the USB-C cable, which you plugged into a USB 2 controller board.
Solution offered: Buy a dirt cheap USB expansion box and a couple of USB-A to USB-C cables to hook it up. MAC C to Box A, Box A to Laser C out.
This is supposed to trick the MAC onto switching to the lower speed USB protocol.
I just got my F1 Ultra and downloaded the latest version of Lightburn. It won’t recognize my laser on a MacBook Pro intel or Mac mini with an Apple M1 (both running OS 14.5 Sonoma). I tried USB-C to USB-C directly and USB-C to USB-A through two different hubs. Both machines recognize the laser when using the Xtool XCS software when using any cable and/or hub, so it seems like this is not a USB connection issue?
This is my first laser and first experience with Lightburn so it’s definitely possible that I’m doing something wrong but any help would be appreciated.
ETA - regarding MikeyH’s post about USB2 vs USB3 speeds: in the system profiler on my laptop under the USB section I am able to see the machine. It’s listed as “MakeBlock” and says it’s running at 480 mb/s which I believe is USB2 speed so I don’t believe that’s the issue
Also, I did install the lbdev file from Xtool as mentioned in the top post
