Connecting to iMac
Hi
I have an iMac running Ventura OS. I can’t get my Atomstack A5 pro to connect. I have downloaded a ver but when I scan for the laser it finds nothing. If I was to create manually which should I select?
Do you have the correct driver installed?
https://sparks.gogo.co.nz/ch340.html
Probably not, I’ll install that one, thank you
I’ve installed it and the two are now connected. Print quality is not good at the moment though
