LIGHT burn ne se connecte pas, es ce un problèlme d’avoir essayer avent GRBL qui s’affiche en permanence? merci pour vos réponses
Wait until the machine is fully started before you try to connect to it with LightBurn. If you try connecting too early there will not be a serial port to connect to.
Once the machine has fully powered on and finished homing, if needed, you can manually select the serial port from the drop list [video], or right-click the ‘Devices’ button to have LightBurn scan for available serial ports and try to connect.
You won’t see GRBL displaying itself in the Console Window until you are connected.
If you are still unable to connect, follow this link to a troubleshooting guide:
