Connot find controller
I recently got a new laptop and I cannot get it to connect to the laser. I have a Monport 80 watt CO2. The USB port got damaged on the laser, so I connect thru an ethernet cord. The new laptop does not have a port so I use an adapter. I have made sure to install the needed drivers and still nothing. HELP :slight_smile:
There is usually a short jumper from the cabinet to the controller. I hope it wasn’t damaged at the controller end?
Are you using the Lightburn bridge?
If you can get on-line with your computer, just put your laser on-line. The Ruida isn’t really designed to work with a system that requires DHCP, or the router giving out addresses. The Ruida is ip address is static.
Nevertheless, it should be relatively simple to just plug it into your router.
:grinning_cat:
This might be a new rabbit hole, but you can tell your router to designate the laser I.P. address as a fixed one and to ignore it in the DHCP assignments.
