I’ve looked at lots of the Ruida manuals on how an dc excited machine is wired. You wiring looks fine.
Before you change any controller values, make a backup of your factory or original settings that it has.
Not having one of these animals, I will give you what I do know about them and that might lead to an answer. We have a couple users here that might be able to help.
The dc excited co2 laser is wired a bit differently but an explanation might help you.
There are two control lines to the lps. PWM sets the current limit via the IN pin. This runs continuously anytime the machine is executing a layer.
The L-On or Laser Enable goes low causing the machine to lase at the IN current limit.
An RF excited laser is driver with only one control line, that is PWM from the controller, L-On is not used. This is RF mode selectable Edit → Machine Setting → Laser Settings
These have a pre-ignition value that is adjustable, this can be disabled in the settings.
It would seem these are driven like a ssl. Based on the fact that pwm period appears to make a big difference. I’ve looked but have never found much on the moudle itself.
All of this has only the pwm connection for control… That’s about my limit.
Everything following is an opinion, ensure you follow and the risk is yours.
I’d suggest reading the voltage from the Ruida pwm terminal. This is the control line to the laser module. It will be a very small voltage. 20% power should generate about 1V. That would be near 10W on your machine, so I’d guess it’s a lot less, more like 1%… or about a tenth of a volt.
I’d try changing it to RF (no pre-ignition)… I don’t think there is any reason that this might damage your machine in any way. Just the resulting burn.
If this changes it, I’m not exactly sure what it tells us, but it’s information we may be able to piece together.
Good luck
