Hi, Trying to cut white vinyl with my diy cutter, but it have some speed limits, high speed cause vibrating and it reduces the quality, that I using only 40% of laser pow, but on white vinyl when he start the cut he skip about 5mm of the trace to get thru in white surface, there is any settings like can set laser pow like 100% for 0.5Sec and continue on 40%?
Cut Through mode will pause at the start of a cut with the laser at a given power and then progress through the cut with the actual cut setting power:
The settings above will hold at the beginning of the cut for 500ms (0.5 sec) at 100% power, then start cutting the shape at 40% power.
