Hello,
Is there a way to control minimun power in ligthburn? as max power is controlled
thank you,
Héctor
Hello,
thank you,
Héctor
No, your lasers do not support this. For using minimum and maximum power, you need a Ruida controller. grbl-Controllers calculate the minimum power value based on the speed profile when using dynamic power mode (M4).
Thank you! even thought it would be a nice feature to control it (like today) and manually.
thanks againg, best regards, Héctor
I do think MIN power is an option for Grayscale images.
Yes, but that’s entirely different. It has the same name, but means a different thing. So people often confuse it. In this case, it is just an image tuning value, nothing else.
Yes, I know, but @HectorJDigrandi did not specify what he was doing.
