Convert file from 4mm to 5mm material
File reads 4 mm material. Can you convert to 5 mm material?
Not sure what you’re asking. Best answer is go to tools > resize slots in selection.
One possibility is to scale up the entire project by the 25%. Lock the aspect ratio and type 125 in the percent field.
If it is not ok with that scaling, you can use the resizer tool that @Dskall has already written.
Excellent example of many solutions to one problem. I’ll write that down in my little black book of Lightburn tips from the masters :wink:
:beers:
Sas
I normally figure the increase or decrease in size as a percentage. Add or subtract that amount from the entire project and everything is usually correct with no further changes.
Found this, .hot tip: Convert 4mm to 5mm
If you are needing to change the size of slots or tabs or both to get things to fit the new material, LightBurn provides the following: :slight_smile:
