Convert .rd file to a format Lightburn can open?
Hey folks, I exported a job from lightburn to a .rd file for my laser. I, of course, never saved the file, and now I need to make a small change to that .rd file.
Is there a way to convert a .rd file into a format that lightburn could interpret again?
Thanks in advance,
Kurtis
You can ‘Open’ or ‘Import’ a .RD file into LightBurn, but you will see only the individual lines sent to the laser to produce your job, so editing (Node Editing) this may not work for what you want to achieve. I suggest you give it a try and see what you get from that file and if you can make the required adjustments. :slight_smile:
