I have just had a problem with converting files with layers to gcode to use directly with with laser from a card.
I have a Creality CR Falcon 10 and replaced with Creality Falcon 2 12W. The second machine was included as a device in between using the original Gcode and using the 2nd gcode…
On Monday the gcode came out in the correct layer order but from today they are coming out in the order that the layers were written.
I have 1:changed the colour of the layers and 2: changed the name of the layer to the order required but the Gcode still comes out in the incorrect order.
This is the start of the original version
; LightBurn 1.4.03
; GRBL device profile, absolute coords
; Bounds: X135 Y7.5 to X265 Y407.5
G00 G17 G40 G21 G54
G90
M4
; Cut @ 1000 mm/min, 70% power
M8
G0 X175Y25.5
G0 Z0
; Layer C01
G1 X260S700F1000
G0 X260Y29.5
G1 X175
G0 X175Y33.5
with all layers in order
This is the new gcode starting incorrectly
; LightBurn 1.4.03
G00 G17 G40 G21 G54
G90
M4
; Cut @ 350 mm/min, 100% power
M8
G0 X265Y407.5
G0 Z0
; Layer C00
G1 Y7.5S1000F350
G1 X135
G1 Y407.5
with the rest in time written as the order
Is this a Lightburn problem or a Creality problem??
