Converting RDworks files to Light Burn files
is there an easy way to convert all my RDworks files to LightBurn files?
The simplest option is to export an AI file from RDWorks and import that into LightBurn, then manually set the layer settings. There is not currently a way to read RDWorks project files.
You can also do this slowly - use RDWorks for project files that you don’t need to change, and use LightBurn for new files, or ones that need to be modified often.
