I’ve been using a Macbook Pro running Sequoia with xTool D1 Pro 20W. I’ve had no problems. I exported a bundle from this macbook and imported it onto a PC running Windows 10. Using the PC, I imported a file, clicked the frame button in Lightburn. The laser went from its home position to the intented area and framed it correctly. When I click start it does NOT proceed to burn, instead it goes back to the home position. The Console lists an “M15 NO” then ends the job. Any ideas would be appreciated!
Jared
I did a search and it seems the M15 is related to the FAN (off) and M14 is FAN (on).
The recommendation was to check settings.
Check Firmware.
Could it be that the Macbook runs ok but the PC is not updated or has the wrong settings.
Hope this helps
