If those lines are really narrow, that could easily be the cause. You’ve also got Min Power set to 20, not 70 - for image engraving, unless you’re using the grayscale image mode, Min and Max power should be set the same.
If the image still doesn’t show after setting Min Power, try using the Image Trace to convert it to a shape and see if that improves it.
