I have designed a coaster for drinks, how do I duplicate it to make several on the same project. 8 will fir on a sheet of basswood plywood.
Select your whole design and hit Ctrl C. Then move your cursor over a little and hit Ctrl D to copy the design.
The outer box will move, however the words and images are not moving
Maybe group first, can you post your project .lbrn2 file?
A bit of info:
Make sure you have selected the whole design before you CTRL+D (makes a copy in exactly the same place) or CTR+C (puts the copy on the clip card for you to Ctrl+V paste as many as you want where your mouse is).
Check your selection by pressing the PREVIEW button (looks like a computer monitor). It is easy to miss a small part of the design, so I like to select all (CTRL+A) and CTRL+G to group into one piece.
How come when I do CTR C and then Crt V, everything that was in the box is gone?
Alternatively use the grid array tool
Group all the elements in the design first
