Whem laying out peg holes on a cribbage board I use copy along path but I have to go in and manually delete every 6th hole to have a space for hole number label. Is their a way to do a group of 5 holes, do a copy along path with the group and have space between the groups. It is a pain to go in and delete every 6th hole manually. because somewhere along the lineI I will end up with a group of 4 when done.
I believe making the first a virtual array, and then copying that as a 2nd array may be a good way to do it.
Do it exactly like that. Make 5 holes, group them together, then use copy along path spacinga s needed.
I have tried that But the group of 5 will not copt along path and stay on path where their are curves.. I spent an hour in a laser group trying different variations of that and it did not work.
You didn’t say there were curves involved. Yes, the group will not bend around a curve, it will stay exactly as grouped (straight line).
I don’t think single holes will work properly either using copy along path then because the outside track has a larger radius than the inside track and the hole spacing is different. I would use groups of 5 for the straight runs and single holes for the radius portions. The straight lines would need to be broken from the radius for this to work.
Screenshots or file uploads of what you’re trying to achieve / working with helps others understand better.
