Copy project from one light burn to another without settings
Hello,In workshop I have 4 co2 lasers and 4 diferent ps with 4 lightburn programs.I need to copy few projects from PC1 to PC 2 and PC3 but I dont want to import speed and setings from PC1 and want to keep text editable.All of them have art library with same name but diferent files so cant just copy whole library.Is there easier way other then creating new library,add projects I want ,save on usb and load that library to diferent PC and open one by one then save where I want?
Thanks in advance
You can import a lbnr2 into an open project, this should give you the desired result, i.e. the existing properties from the layers will be applied to the imported project.
thanks for solution
