Cork burns easily, sometimes only a hard look at it will cause it to burst into flame. I’ve done cork and used the bare minimum for my machine (60W) , about 12-15% and a couple hundred millimeters per second. For your tube power, use the lowest power setting you can manage. You can always turn it higher, but I’d expect you’ll get a good burn at the low end.
