Corner rounder freaking out
Think I found a possible bug. Working on some halloween designs and doing a small corner rounding (2mm on a 60mm tall item) I click on either of the bottom corners of the item shown on the bottom and the end result is the item shown on the top. Now you can see I did the same 2mm rounding on the sides and top shoulders with no issues but when I try on the bottom corners it freaks out and makes the hole thing pointed at the bottom and over 100mm tall then.
I really wanted to just break the sharp corners a bit but right now I am at a loss since the corner rounder is freaking out.
Any ideas?
Can you upload your file? I couldn’t reproduce it on my end.
BadRadius.lbrn2 (10.2 KB)
I did re-draw the shape from scratch and it then worked but curious why it did not on the original. I uploaded it so you can take a look.
Your bottom line is a arc. If you change it to a straight line, it will work like you want.
OK, got it. Thanks
