I deleted the first post as I had to correct a file and add two more. Read the description in the thingiverse details. The shorter bracket version 2 and short base are designed so that you do not have to drill the laser deck but rather use an industrial grade adhesive tape double sided. If you have ever used this you will never get the base piece off without seriously prying so it will ho,d a laser tube forever…just do not use regular stuff is all.
As always it is free to use but you may not sell a printed part or sell the stl as stated in the license. You may remix as seen fit
