Quick question about power settings in control panel & lightburn.
How or Does the limit set on the laser control power correlate to the settings in lightburn?
Does setting the max power at 70% in the control panel mean that the Lightburn burn is now a percentage of that? Like a 50% burn is now 50% of the 70% max, or is it independent and lightburn will run-up to the 70% control panel limit and not go over.
no lightburn (and the ruida) only use a % of the total power.
You have the max power you set in the vendor settings and the software cannot override that
