Corte de circulos imperfecto
Hola, tengo una Sculpfun S30 Pro de 20W y los círculos los corta deformados.
Alguien puede ayudar a solucionarlo.
Saludos.
Even without pictures to show us your problem, I suspect you have what causes this 95% of the time. Check all the grub (set) screws for tightness. Also make sure the belts are snug and no wiring is catching on the laser or trolley.
