Alguien sabe por qué me pasa esto, el corte que hago si lo llego a pasar 2 o más pasadas me lo mueve,
Alguien sabe cómo se soluciona?
This is likely a mechanical issue. Do a mechanical review of your system but especially focus on belt tension and check that the pinion gears are properly secured to the shaft of the stepper axis. It looks like you’re losing motion on the X-axis.
