Count in Framing - JCZ Galvo
Hello, I love to use Lightburn instead of EZCAD2, and at first I want to say that this is not a hate but constructive criticism. There is one thing that is really inconvenient for me and that is the operation count being availible only in the framing window. I think this might be an issue for more people than just me.
I really do not like to be forced to have that window open as I do not use it most of the times and I forget to open it to have the counting active. Then I have to manually count the number of produced pieces and that is a big problem as we do thousands. We also use automatic feeders with co2 galvos. I do not really understand why we have to frame every single piece to have the count active. I also do not like to be forced to move the mirrors all the time and reduce their lifetime by constant unecessary framing.
Would it be possible to also include the count outside the framing window? Or is there any trick to force the software to count without the framing window? This is the only thing that keeps me from the 100% switch from EZCAD to LIGHTBURN.
Thanks for any feedback on this.
Lukas
Hi Lukas,
We don’t have the “Count” in the Laser window, so the “Live Framing” window is needed.
As a workaround, you could:
  • Enable “Require Framing before Start” in the Device Settings
  • slow down the “Framing Speed”
  • draw a dummy shape on one of the Tool Layers, and enable “Tool Layers Only” in the Framing Window:
Thanks for the workarounds and your reply. Is there any chance that this will just be a check box to appear in the standard lightburn workplace somewhere, same way as the EZCAD has this? Someone would allow that, someone would not care. It would be great to just have it as a feature. Is this complicated upgrade? Thanks in advance for your time
Lukas
It’s certiainly doable, but wouldn’t be a quick simple toggle.
We welcome suggestions on new features at https://lightburn.fider.io/ - we’d suggest you make a post there detailing the feature you wish to see. We use Fider to help us choose which features are most important for us to develop next.
