The back of a multi layer Covid bar sign. Engraved using 45 degree cross hatch settings in Lightburn. 6mm birch ply.
I really like that look - It’s not often that someone uses this feature either, so kudos.
Thanks Oz. Nice quick way to fill big areas and it leaves a surface that is less prone to damage when rubbed against. I need to fine tune my settings for this work, the longer runs faded out a bit in the middle, but actually that created a subtle 3 d effect.
Adjusting the Min / Max power will help a bit with that. Unlike normal scans, angled runs like this are ‘faked’ using standard cutting moves, so it doesn’t do automatic overscanning, and does use the min / max power settings.
