crash Mac OS Ventura
Hello,
I’m testing MillMage RC on macOS Ventura 13.7.8 (MacBook Pro).
When I validate the 30-day trial license and click OK, the application closes immediately.
When I run it from Terminal (/Applications/MillMage.app/Contents/MacOS/MillMage), I get the following log:
QCoreApplication::postEvent: Unexpected null receiver
NSDocumentController Info.plist warning: The values of CFBundleTypeRole entries must be 'Editor', 'Viewer', 'None', or 'Shell'.
Not using a managed prefs dir:
/Users/USERNAME/Library/Preferences/MillMage_PreRelease
qt.core.qobject.connect: QObject::connect: No such signal QNetworkReplyHttpImpl::error(QNetworkReply::NetworkError)
zsh: segmentation fault  /Applications/MillMage.app/Contents/MacOS/MillMage
It looks like a Qt network issue when the app tries to reach the license server.
On Ventura the crash is 100% reproducible, right after the license activation window.
Can you confirm if this is a known bug in the RC, and if there is a workaround (or should we wait for the next build)?
Thanks!
You did not say which RC version you are using.
J’ai testé toutes les versions. Même problèmes
I tested all versions. Same problems.
I usw Windows, but I have not seen anything like this for the MAC.
This suggests there is a file folder permissions issue.
